Dynamic grammars and semantic analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
We define a dynamic grammar as a device which may generate an unbounded set of context-free grammars, each grammar is produced, while parsing a source text, by the recognition of some construct. It is shown that dynamic grammars have the formal power of Turing machines. For a given source text, a dynamic grammar, when non ambiguous, may be seen as a sequence of usual context-free grammars specialized by this source text: an initial grammar is modified, little by little, while the program is parsed and is used to continue the parsing process. An experimental system which implements a non ambiguous \sl dynamic parser is sketched and applications of this system for the resolution of some semantic analysis problems are shown. Some of these examples are non-trivial (overloading resolution, derived types, polymorphism, \ldots) and indicate that this method may partly compete with other well-known techniques used in type-checking.
RR-2322.pdf (373.53 Ko) Télécharger le fichier
inria-00074352 , version 1 (24-05-2006)
  • HAL Id : inria-00074352 , version 1
Pierre Boullier. Dynamic grammars and semantic analysis. [Research Report] RR-2322, INRIA. 1994. ⟨inria-00074352⟩
275 Consultations
296 Téléchargements
