A Differential Geometric Setting for Dynamic Equivalence and Dynamic Linearization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1994
This paper presents an (infinite dimensional) geometric framework for control system, based on infinite jet bundles, where a system is represented by a single vector field and dynamic equivalence (to be precise~: equivalence by endogenous dynamic feedback) is conjugation by diffeomorphisms. These diffeomorphisms are very much related to Lie-Bäcklund transformations. It is proved in this framework that dynamic equivalence of single-input systems is the same as static equivalence.
RR-2312.pdf (369.1 Ko) Télécharger le fichier
inria-00074361 , version 1 (24-05-2006)
  • HAL Id : inria-00074361 , version 1
Jean-Baptiste Pomet. A Differential Geometric Setting for Dynamic Equivalence and Dynamic Linearization. RR-2312, INRIA. 1994. ⟨inria-00074361⟩
Relations
179 Consultations
202 Téléchargements
