New interface
Reports (Research report)
Computing Differential Properties of 3-D Shapes from Stereoscopic Images without 3-D Models
Frédéric Devernay 1 Olivier Faugeras 1
1 ROBOTVIS - Computer Vision and Robotics
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : We are considering the problem of recovering the three-dimensional geometry of a scene from binocular stereo disparity. Once a dense disparity map has been computed from a stereo pair of images, one often needs to calculate some local differential properties of the corresponding 3-D surface such as orientation or curvatures. The usual approach is to build a 3-D reconstruction of the surface(s) from which all shape properties will then be derived without ever going back to the original images. In this paper, we depart from this paradigm and propose to use the images directly to compute the shape properties. We thus propose a new method extending the classical correlation method to estimate accurately both the disparity and its derivatives directly from the image data. We then relate those derivatives to differential properties of the surface such as orientation and curvatures. We present the results of the reconstruction and of the estimation of the surface orientation and curvatures on some stereo pairs of real images.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00074369
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 3:09:52 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:11 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 4:45:37 PM
Identifiers
  • HAL Id : inria-00074369, version 1
Collections
Citation
Frédéric Devernay, Olivier Faugeras. Computing Differential Properties of 3-D Shapes from Stereoscopic Images without 3-D Models. [Research Report] RR-2304, INRIA. 1994. ⟨inria-00074369⟩
Share
Metrics
Record views
112
Files downloads
146
