Feature-based shape transformation for polyhedral objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
A new technique is presented for computing transformations between polyhedral objects. Here, the correspondence and the interpolation problems are considered jointly. The approach gives the animator high level control of the shape transformation by providing natural specification and interaction
RR-2264.pdf (427.08 Ko) Télécharger le fichier
inria-00074407 , version 1 (24-05-2006)
  • HAL Id : inria-00074407 , version 1
Francis Lazarus, Anne Verroust. Feature-based shape transformation for polyhedral objects. [Research Report] RR-2264, INRIA. 1995. ⟨inria-00074407⟩
60 Consultations
100 Téléchargements
