Abstract : lambda-upsilon-calculus is a new simple calculus of explicit substitutions. In the paper we explore its properties, namely we prove that it correctly implements B reduction, it is confluent, its simply typed version is strongly normalizing. We associate with it an abstract machine called the U-machine. We prove that it is a correct implementation of the calculus.
