HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Prediction of the behaviour of an unreliable system : application to the choice of the optimal maintenance policy
Abstract : We consider a system the state of which is represented by the value of a unique variable. The state of the system can be observed at regular intervals of time. It evolves from one instant to the next one according to an exponential distribution. The system breakdowns if the state exceeds a given limit. In this case, it must be repaired, which results to a repair cost. It is also possible to maintain the system, i.e. to inspect it and, if required, adjust it before it breaks down. This results in a maintenance cost usually much smaller than the repair cost. We aim at defining a warning-value less than the breakdown limit such that, if the state lays between the warning value and the breakdown limit, a maintenance operation is performed to the system. The goal is to minimize the average cost.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074464
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 3:21:39 PM
Last modification on : Friday, February 4, 2022 - 3:25:25 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 3:41:20 PM
Identifiers
  • HAL Id : inria-00074464, version 1
Citation
Chengbin Chu, Jean-Marie Proth, Philippe Wolff. Prediction of the behaviour of an unreliable system : application to the choice of the optimal maintenance policy. [Research Report] RR-2207, INRIA. 1994, pp.20. ⟨inria-00074464⟩
Share
Metrics
Record views
52
Files downloads
31
