Randomized graph drawing with heavy-duty preprocessing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
We present a graph drawing system for general undirected graphs with straight-line edges. It carries out a rather complex set of preprocessing steps, designed to produce a topologically good, but not necessarily nice-looking layout, which is then subjected to Davidson and Harel's simulated annealing beautification algorithm. The intermediate layout is planar for planar graphs and attempts to come close to planar for nonplanar graphs. The system's results are significantly better and much faster, than what the annealing approach is able to acchieve on its own.
Autre [cs.OH]
RR-2147.pdf (1.15 Mo) Télécharger le fichier
inria-00074525 , version 1 (24-05-2006)
  • HAL Id : inria-00074525 , version 1
David Harel, Meir Sardas. Randomized graph drawing with heavy-duty preprocessing. [Research Report] RR-2147, INRIA. 1993. ⟨inria-00074525⟩
120 Consultations
72 Téléchargements
