Optimal tiling
Iteration space tiling is a common strategy used by parallelizing compilers to reduce communication overhead. We address the problem of determining the optimal tile size (which minimizes the total execution time of the program), for a particular program schema. We use a realistic model of the architecture which accounts for coprocessors that permit overlapping of communication and computation, context switching times, etc. Determining the optimal tile size is shown to reduce to a non-linear optimization problem. We solve this analytically, yielding a closed form solution that involves only parameters of the architecture and program that are easily determined at compile time. It can thus be used by a compiler before code generation. Although we solve the problem for a particular schema of programs, our results can be generalized to uniform dependence loops and also to certain classes of lopp programs with dynamic dependence vectors.
