Languages with reducing reflexive types, 7th Coll. on Automata , Languages and Programming, pp.38-50, 1980. ,
DOI : 10.1007/3-540-10003-2_58
The Lambda Calculus. Its Syntax and Semantics, 1981. ,
Needed reduction and spine strategies for the lambda calculus [4] P. Crégut. An abstract machine for the normalization of ?-terms, Proc. of the ACM Conf. on Lisp and Functional Programming, pp.191-231, 1987. ,
Lambda-calculus schemata, Proc. of the ACM Conf. on Proving Properties about Programs, Sigplan Notices, pp.104-109, 1972. ,
DOI : 10.1007/bf01019461
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.15.8355
Compilation of functional languages by program transformation, ACM Transactions on Programming Languages and Systems, vol.13, issue.1, pp.21-51, 1991. ,
DOI : 10.1145/114005.102805
URL : https://hal.archives-ouvertes.fr/inria-00075518
What is an efficient implementation of the ??-calculus?, Proc. of the ACM Conf. on Functional Prog. Languages and Comp. Arch. Transformations and reduction strategies for typed lambda expressions, pp.289-312, 1991. ,
DOI : 10.1007/3540543961_14
Supercombinators, a new implementation method for applicative languages, Proc. of the ACM Conf. on Lisp and Functional Programming, pp.603-631, 1982. ,
Orbit, proc. of 1986 ACM SIGPLAN Symp. on Comp. Construction, pp.219-233, 1986. ,
DOI : 10.1145/989393.989414
An algorithm for optimal lambda calculus reduction, Proceedings of the 17th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '90, pp.16-30, 1990. ,
DOI : 10.1145/96709.96711
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.90.2386
Réductions correctes et optimales dans le lambda calcul, Thèse de doctorat d'état, 1978. ,
A representation of Lambda terms suitable for operations on their intensions, Proceedings of the 1990 ACM conference on LISP and functional programming , LFP '90, pp.341-348, 1990. ,
DOI : 10.1145/91556.91682
An overview of ?Prolog, Proc. of the 5th Int. Conf. on Logic Prog, pp.810-827, 1988. ,
Call-by-name, call-by-value and the ?-calculus. Theoretical Computer Science, pp.125-159, 1975. ,
A graph-like lambda calculus for which leftmost-outermost reduction is optimal, Graph Grammars and their Application, pp.440-455, 1978. ,
DOI : 10.1007/BFb0025740
Semantics and Pragmatics of the Lambda-Calculus, 1971. ,
