Time-varying exponential stabilization of nonholonomic systems in power form - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
Systems in canonical power form have recently been used to model the kinematic equations of nonholonomic mechanical systems. McCloskey and Murray have had the idea of using the properties of homogeneous systems to derive exponentially stabilizing continuous time-periodic feedbacks for this class of systems. Motivated by this work, the present study extends a control design method previously proposed by Samson to the design of such homogeneous feedbacks. The approach here followed has the advantage of yielding simple and direct stability proofs. Homogeneity-related results needed for time-varying exponential stabilization are also provided.
Autre [cs.OH]
RR-2126.pdf (352.99 Ko) Télécharger le fichier
inria-00074546 , version 1 (24-05-2006)
inria-00074546 , version 2 (07-08-2006)
  • HAL Id : inria-00074546 , version 2
Jean-Baptiste Pomet, Claude Samson. Time-varying exponential stabilization of nonholonomic systems in power form. [Research Report] RR-2126, INRIA. 1993. ⟨inria-00074546v2⟩
207 Consultations
372 Téléchargements
