Nested loop sequences : towards efficient loop structures in automatic parallelization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
An important problem in automatic parallelization of scientific programs is to generate loops from an algebraic description of the iteration domain. The usual technique is to produce a perfectly nested set of loops, whose bounds consist in maxima and minima of several affine functions. However, perfect loop nests suffer from the run-time overhead of evaluating bound expressions and do not allow to scannon-convex domains efficiently. In this paper we study a candidate loop structure for overcoming these problems. This structure, called nested loop sequence (NLS) is defined as a sequence of DO loops whose bodies are nonempty sequences of DO loops. We propose an algorithm to compute a NLS scanning a given convex polyhedron, which overcomes the run-time overhead problem. The algorithm produces a loop structure in which the bounds of every loop consist each in a single affine functions.
Autre [cs.OH]
RR-2094.pdf (230.48 Ko) Télécharger le fichier
inria-00074578 , version 1 (24-05-2006)
  • HAL Id : inria-00074578 , version 1
Zbigniew Chamski. Nested loop sequences : towards efficient loop structures in automatic parallelization. [Research Report] RR-2094, INRIA. 1993. ⟨inria-00074578⟩
50 Consultations
237 Téléchargements
