An Efficient implementation of sequentially consistent distributed shared memories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
Recently, distributed shared memory systems have received much attention because such an abstraction simplifies programming. In this paper, we present a data consistency protocol for a distributed system which implements sequentially consistent memories. The protocol is aimed at an environment where no special support for atomic broadcast exists. As compared to previously proposed protocols, our protocol eliminates the need of atomic broadcast and significantly reduces the amount of information flow among the processors. This is realized by maintaining state information and capturing causal relations among read and write operations.
Autre [cs.OH]
RR-2085.pdf (230.54 Ko) Télécharger le fichier
inria-00074587 , version 1 (24-05-2006)
  • HAL Id : inria-00074587 , version 1
Masaaki Mizuno, Michel Raynal, Gurdip Singh, Mitchell L. Neilsen. An Efficient implementation of sequentially consistent distributed shared memories. [Research Report] RR-2085, INRIA. 1993. ⟨inria-00074587⟩
104 Consultations
233 Téléchargements
