HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Multilevel optimization : application to shape optimum design with a one-shot method
Abstract : Gradient method is applied to the optimal control of a system for which each simulation is expensive. Instead of solving completely the flow equation as a state equation in the shape optimization, we use a "one-shot method" which solves simultaneously the system optimality. It is tested for the problem of shape optimization of a nozzle in a 2D Euler flow.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074604
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 3:53:01 PM
Last modification on : Friday, February 4, 2022 - 3:18:24 AM
Long-term archiving on: : Monday, April 5, 2010 - 12:12:03 AM
Identifiers
  • HAL Id : inria-00074604, version 1
Collections
Citation
Nathalie Marco, François Beux. Multilevel optimization : application to shape optimum design with a one-shot method. [Research Report] RR-2068, INRIA. 1993. ⟨inria-00074604⟩
Share
Metrics
Record views
56
Files downloads
184
