Min-max certainty equivalence principle and differential games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
This paper presents a version of the certainty equivalence principle, usable for nonlinear, variable end-time, partial observation zero-sum differential games, which states that under the unicity of the solution to the auxiliary problem, optimal controllers can be derived from the solution of the related perfect observation game. An example is provided where in one region, the new extended result holds, giving an optimal control and in another region, the unicity condition is not met, leading indeed to a non-certainty equivalent optimal controller.
Autre [cs.OH]
RR-2019.pdf (672.23 Ko) Télécharger le fichier
inria-00074652 , version 1 (24-05-2006)
  • HAL Id : inria-00074652 , version 1
Pierre Bernhard, Alain Rapaport. Min-max certainty equivalence principle and differential games. [Research Report] RR-2019, INRIA. 1993. ⟨inria-00074652⟩
209 Consultations
156 Téléchargements
