Fine grain parallelism on a MIMD machine using FPGAs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
Dominique Lavenier
Stéphane Rubini
Bernard Pottier
Current MIMD machines are used for coarse grain-parallelism and also offer message passing mechanisms to deal with inter-processor communications. But these mechanisms lack efficiency in fine-grain parallel applications such as systolic computation. This article presents the use of an FPGA chip to set up a fast systolic communication agent on a linear asynchronous network of Transputer processors, the machine is called ARMEN.
Autre [cs.OH]
RR-1983.pdf (213.11 Ko) Télécharger le fichier
inria-00074689 , version 1 (24-05-2006)
  • HAL Id : inria-00074689 , version 1
Frédéric Raimbault, Dominique Lavenier, Stéphane Rubini, Bernard Pottier. Fine grain parallelism on a MIMD machine using FPGAs. [Research Report] RR-1983, INRIA. 1993. ⟨inria-00074689⟩
306 Consultations
597 Téléchargements
