HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Pseudopower expansion of solutions of generalized equations and constrained optimization problems
J. Frederic Bonnans 1
1 PROMATH - Mathematical Programming
Inria Paris-Rocquencourt
Abstract : We compute the solution of a strongly regular perturbed generalized equations as the sum of a speudopower expansion, i.e. the expansion at order k is the solution of the generalized equation expanded at order k and thus depends itself on the perturbation parameter [??]. In the polyhedral case, the pseudopower expansion reduces to a classical Taylor expansion. For constrained optimization problems with strongly regular solution, we check that the quadratic growth condition holds and that, at least locally, solutions of the problem and solutions of the associated optimality system coincide. In the special case of a finite number of inequality constraints, the solution and the Lagrange multiplier can be expanded in Taylor series if the gradients of the active constraints are linearly independent. If the data are analytic, the solution and the multiplier are analytic functions in [??] provided that some strong second order condition holds.
Complete list of metadata
https://hal.inria.fr/inria-00074717
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 4:08:00 PM
Last modification on : Thursday, February 3, 2022 - 11:18:53 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 6:28:24 PM
Identifiers
  • HAL Id : inria-00074717, version 1
Collections
Citation
J. Frederic Bonnans. Pseudopower expansion of solutions of generalized equations and constrained optimization problems. [Research Report] RR-1956, INRIA. 1993. ⟨inria-00074717⟩
Share
Metrics
Record views
114
Files downloads
77
