Maneuver-based obstacle-avoiding trajectory optimization
The problem of maneuvering complex vehicles through obstacles is considered. The proposed solution consists in searching the optimal path through a tree of trajectory segments. Since these segments of trajectory, called maneuvers are precalculated this method can be used for real-time applications very efficiently. The approach is illustrated through the example of a riderless bicycle.
