A Trust region interior point algorithm for linearly constrained optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
J. Frederic Bonnans
  • Fonction : Auteur
  • PersonId : 833418
  • IdHAL : bonnans
Cecilia Pola
  • Fonction : Auteur
We present an extension for nonlinear optimization under linear constraints, of an algorithm for quadratic programming using a trust region idea, introduced by Ye and Tse and extended by Bonnans and Bouhtou. Due to the nonliearity of the cost we use a linesearch in order to reduce the step if necessary. We prove that, under suitable hypotheses, the algorithm converges to a point satisfying the first-order optimality system and we analyse under which conditions the unit stepsize will be asymptotically accepted.
RR-1948.pdf (608.74 Ko) Télécharger le fichier
inria-00074725 , version 1 (24-05-2006)
  • HAL Id : inria-00074725 , version 1
J. Frederic Bonnans, Cecilia Pola. A Trust region interior point algorithm for linearly constrained optimization. [Research Report] RR-1948, INRIA. 1993. ⟨inria-00074725⟩
136 Consultations
107 Téléchargements
