Unstructured volume-agglomeration MG : solution of the Poisson equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
We are interested in solving second-order PDE's with multigrid and unstructured meshes. The multigrid strategy we present here is adapted from the generalized finite volume agglomeration multigrid algorithm we have developed recently for the solution of the Euler equations. We now focus on the Poisson's equation. A strategy is defined by introducing a correction factor for the diffusive terms and some illustrating results are given.
Autre [cs.OH]
RR-1946.pdf (921.16 Ko) Télécharger le fichier
inria-00074727 , version 1 (24-05-2006)
  • HAL Id : inria-00074727 , version 1
Bruno Koobus, Marie-Hélène Lallemand, Alain Dervieux. Unstructured volume-agglomeration MG : solution of the Poisson equation. [Research Report] RR-1946, INRIA. 1993. ⟨inria-00074727⟩
153 Consultations
514 Téléchargements
