ParaGraph : an interactive environment for parallelizing FORTRAN programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
This report presents the implementation of ParaGraph, a parallelizer for F, a subset of the FORTRAN language, in the CENTAUR system. Using TYPOL, the dynamic semantics of the language has been formally defined, dependence graphs computed and a standard set of transformations has been specified. An interactive user interface based on the SOPHTALK message based system has then been experimented.
Autre [cs.OH]
RR-1920.pdf (1.88 Mo) Télécharger le fichier
inria-00074754 , version 1 (24-05-2006)
  • HAL Id : inria-00074754 , version 1
Bernard Dion, Laurent Angeli, Angel Bravo Lastra. ParaGraph : an interactive environment for parallelizing FORTRAN programs. [Research Report] RR-1920, INRIA. 1993. ⟨inria-00074754⟩
348 Consultations
161 Téléchargements
