New interface
Reports (Research report)
Node-nested multi-grid method with Delaunay coarsening
Hervé Guillard 1
1 SINUS - Numerical Simulation for the Engineering Sciences
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : For finite-element non-structured type meshes, the non-nested multigrid algorithms require to build a sequence of independent meshes. The paper proposes an automatic way to generate the coarse meshes given the finest one. The method first eliminates a set of points from the current mesh level and then uses the Delaunay-Voronoi algorithm to triangulate the remaining set of points. The algorithm is presented and it is shown that it owns good properties with respect to multigrid algorithms. Several examples of its application to bi-dimensional meshes are presented.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00074773
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 4:16:47 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:39 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:22:42 PM
Identifiers
  • HAL Id : inria-00074773, version 1
Collections
Citation
Hervé Guillard. Node-nested multi-grid method with Delaunay coarsening. [Research Report] RR-1898, INRIA. 1993. ⟨inria-00074773⟩
Share
Metrics
Record views
116
Files downloads
171
