HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Interactive axial deformations
Abstract : This paper presents an interactive deformation technique. The entity employed for defining the deformation of an object is a 3D axis as well as some associated parameters. The technique allows an easy specification and control of deformations that can be defined with that entity such as bending, twisting and scaling. Contrary to existing techniques, the method developed is independent of both the geometric model of the object to be deformed and the creation technique used to define the object. Moreover, it can easly be intagred into traditional interactive modeling systems.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074780
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 4:18:14 PM
Last modification on : Friday, February 4, 2022 - 3:08:12 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:23:09 PM
Identifiers
  • HAL Id : inria-00074780, version 1
Collections
Citation
Francis Lazarus, Sabine Coquillart, Pierre Jancene. Interactive axial deformations. [Research Report] RR-1891, INRIA. 1993. ⟨inria-00074780⟩
Share
Metrics
Record views
136
Files downloads
209
