Abstract : The paper addresses the flow control problem of multi-level assembly production systems in which a unique finished product is obtained from the initial components by successive assembly operations. The manufacturing process of the finished product can be represented as a tree-like graph. We assume that the production capacity of each machine is constant and that the demand is known over the whole problem horizon. Backlogging is not allowed. The flow control problem consists in adjusting the production of the machines in order to minimize the total cost incurred by holding components and the finished product. Properties of the optimal solutions are established. We then propose a simple analytical solution based on these properties.
https://hal.inria.fr/inria-00074796
Contributor : Rapport de Recherche Inria <>
Submitted on : Wednesday, May 24, 2006 - 4:26:27 PM Last modification on : Thursday, February 11, 2021 - 2:48:12 PM Long-term archiving on: : Tuesday, April 12, 2011 - 7:23:22 PM
Ahmedou Haouba, Xiaolan Xie. Flow control of multi-level assembly systems with a unique finished product. [Research Report] RR-1877, INRIA. 1993, pp.20. ⟨inria-00074796⟩
