An Entropy criterion for assessing the number of clusters in a mixture model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1993
Gilles Celeux
G. Soromenho
  • Fonction : Auteur
In this paper, we consider an entropy criterion to estimate the number of clusters arising from a mixture model. This criterion is derived from a relation linking the likelihood and the classification likelihood of a mixture. Its performances are investigated through Monte-Carlo numerical experiments and show favourable results as compared with other classical criteria.
Autre [cs.OH]
RR-1874.pdf (650.55 Ko) Télécharger le fichier
inria-00074799 , version 1 (24-05-2006)
  • HAL Id : inria-00074799 , version 1
Gilles Celeux, G. Soromenho. An Entropy criterion for assessing the number of clusters in a mixture model. RR-1874, INRIA. 1993. ⟨inria-00074799⟩
370 Consultations
3687 Téléchargements
