An Adaptative algorithm for incremental evaluation of production rules in databases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
Mireille Regnier
  • Fonction : Auteur
  • PersonId : 833582
Eric Simon
  • Fonction : Auteur
Several incremental algorithms have been proposed ro evaluate database production rule programs. They all derive from existing incremental algorithms, lke RETE and TREAT, developed for rule-based systems in the framework of artificial intelligence. In this paper, we address a specific but crucial problem that arises with these incremental algorithms : how much data should be profitably materialized and maintained in order to speed-up program evaluation ?. We show that the answer exposes to a well known space-time tradeoff. Our major contribution is to propose and adaptive algorithm that takes as input a program of rules and returns for each rule, the set of most profitable relational expressions that should be maintained in order to obtain a good space-time compromise. A notable feature of our algorithm is that it works for both set-oriented and instance-oriented rules. We compare our algorithms with existing incremental algorithms for database production rule programs.
Autre [cs.OH]
RR-1870.pdf (1.14 Mo) Télécharger le fichier
inria-00074803 , version 1 (24-05-2006)
  • HAL Id : inria-00074803 , version 1
Françoise Fabret, Mireille Regnier, Eric Simon. An Adaptative algorithm for incremental evaluation of production rules in databases. [Research Report] RR-1870, INRIA. 1993. ⟨inria-00074803⟩
99 Consultations
27 Téléchargements
