Abstract : A finite-volume/finite-element method developped in CFD is applied to solve numerically the time-dependent 2D Maxwell system. We use a third-order accurate explicit scheme with triangular meshes. We are particularly concerned here with scattering problems for both homogeneous and non-homogeneous materials. Radar cross section calculations are presented and compared with exact or integral method solutions. A parallel version of the algorithm on the connection machine is presented and the performances are compared with those obtained with a fully vectorized version on the Cray YMP.
https://hal.inria.fr/inria-00074806 Contributor : Rapport de Recherche InriaConnect in order to contact the contributor Submitted on : Wednesday, May 24, 2006 - 4:27:46 PM Last modification on : Friday, February 4, 2022 - 3:15:42 AM Long-term archiving on: : Tuesday, April 12, 2011 - 7:27:40 PM
