HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Waveform inversion through MBTT formulation
Abstract : This work deals with automatic determination of background velocity from full waveform data. For this purpose we have designed, in an earlier work, an original approach based on the MBTT (Migration Based Travel Time) reformulation of the waveform acoustic inversion problem. The goal of this paper is to give the present status of the development of this approach. We first describe how, with this approach, we can handle the multishot data which are required to obtain low frequency information on the background velocities. We present then in detail four steps towards the implementation of this approach : separation of propagator/ reflector unknowns via multiscale analysis, separate imaging of impedance and velocity reflectivity, amplitude preserving migration for the proper imaging of deep reflectors, determination of velocities and impedance from their background values and the two corresponding reflectivities. Each step is illustrated on a synthetic test example. Finally we give numerical evidence that, already in the case of a single shot, the MBTT approach yields a dramatic improvement of the objective function, which becomes convex and looses all parasitic local minima, and we describe the calculation of the gradient of the new objective function.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074833
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 4:32:06 PM
Last modification on : Friday, February 4, 2022 - 3:08:11 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 7:38:02 PM
Identifiers
  • HAL Id : inria-00074833, version 1
Collections
Citation
Guy Chavent, François Clément. Waveform inversion through MBTT formulation. [Research Report] RR-1839, INRIA. 1993. ⟨inria-00074833⟩
Share
Metrics
Record views
248
Files downloads
128
