Decomposed software pipelining
Abstract : This report presents a new view on software pipelining in which we consider software pipelining as an instruction level transformation from a vector of one-dimension to a matrix of two-dimensions. Thus, the software pipelining problem can be naturally decomposed into two subproblems, one to determine the row-number of operations in the matrix and another to determine the column-numbers. Using this view-point as a basis, we develop a new loop scheduling approach, called decomposed software pipelining, to exploit instruction-level parallelism for any loop with/without conditional jumps.
Type de document :
Rapport
[Research Report] RR-1838, INRIA. 1993
Liste complète des métadonnées
https://hal.inria.fr/inria-00074834
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 16:32:13
Dernière modification le : vendredi 16 septembre 2016 - 15:19:38
Document(s) archivé(s) le : dimanche 4 avril 2010 - 22:24:19
Fichiers
  • HAL Id : inria-00074834, version 1
Collections
Citation
J. Wang, Christine Eisenbeis. Decomposed software pipelining. [Research Report] RR-1838, INRIA. 1993. 〈inria-00074834〉
Métriques
Consultations de la notice
138
Téléchargements de fichiers
104
