Overview of the Koan programming environment for the iPSC/2 and performance evaluation of the because test program 2.5.1 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
In this paper, we describe a Fortran programming environment using the Koan shared virtual memory. We then discuss its use for parallelizing a Because benchmark application.
Autre [cs.OH]
RR-1821.pdf (691.45 Ko) Télécharger le fichier
inria-00074851 , version 1 (24-05-2006)
  • HAL Id : inria-00074851 , version 1
François Bodin, Thierry Priol. Overview of the Koan programming environment for the iPSC/2 and performance evaluation of the because test program 2.5.1. [Research Report] RR-1821, INRIA. 1992. ⟨inria-00074851⟩
109 Consultations
119 Téléchargements
