Abstract : In this paper we intend to give an exact analytical evaluation of some parameters arising in a general bin-packing problem. There is an infinite sequence of cells ranked from the left to the right. A cell is either empty, either busy, i.e. contains an item. Items are generated over the cells according to independent Poisson processes of l item per cell and per time unit. When an item is generated on an empty cell it enters the cell which therefore becomes busy. When an item is generated on a busy cell, it tries the next cell on the right and so forth, until it finds an empty cell which it enters. Each stored item has a sojourn time in the cell which is supposed to be exponential of mean one. When the item leaves a cell it disappears completely, i.e. quits the system, the cell immediately becomes empty and available for a next item. We give an exact evaluation of the steady state of the system in terms of a Taylor expansion with respect to variable l.
