A Parallel probabilistic algorithm to find "all" vertices of a polytope - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1992
Ivan Lavallee
  • Function : Author
Pham Canh Duong
  • Function : Author
This paper presents a new parallel algorithm to find all vertices of a convex polytope. This algorithm is of Monte-Carlo type and requires no assumption of problem nondegeneracy. Redundant constraints have no influence on the main computation. The vertex locating routine uses a new algorithm for nearest point problem in polytopes.
RR-1813.pdf (545.16 Ko) Télécharger le fichier
Dates and versions
inria-00074859 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00074859 , version 1
Cite
Ivan Lavallee, Pham Canh Duong. A Parallel probabilistic algorithm to find "all" vertices of a polytope. [Research Report] RR-1813, INRIA. 1992. ⟨inria-00074859⟩
86 View
38 Download
Share
