Interleaved parallel schemes : improving memory throughput on supercomputers
On many commercial supercomputers, several vector register processors share a global highly interleaved memory in a MIMD mode. When all the processors are working on a single verctor loop, a significant part of the potential memory throughput may be wasted due to the asynchronism of the processors. In order to limit loss of memory throughput, a SIMD synchronization mode for vector accesses to memory may be used. But an important part of the memory bandwith may be wasted when accessing vectors with an even stride. In this paper, we present IPS, an interleaved parallel scheme, which ensures an equitable distribution of elements on a highly interleaved memory for a wide range a vector strides. We show how to organize access to memory, such that unscrambling of vectors from memory to the vector register processors requires a minimum number of passes through the interconnection network.
