Abstract : This paper addresses the problem of debugging distributed programs executing on distributed memory parallel computers with message-passing interprocess communication. The main issues of debugging such programs are exposed. Principles for designing and implementing a debugger for programs specified in the Estelle language are presented. All the described solutions have been implemented in a distributed debugger called EREBUS.
https://hal.inria.fr/inria-00074947 Contributor : Rapport de Recherche InriaConnect in order to contact the contributor Submitted on : Wednesday, May 24, 2006 - 5:02:40 PM Last modification on : Friday, February 4, 2022 - 3:22:29 AM Long-term archiving on: : Tuesday, April 12, 2011 - 8:14:01 PM
Michel Hurfin, Noël Plouzeau, Michel Raynal. EREBUS: a debugger for asynchronous distributed computing systems. [Research Report] RR-1613, INRIA. 1992. ⟨inria-00074947⟩
