Abstract : We give an analytical evaluation of the behaviour of the free access stack algorithm when the imput load, l packet per slot, is above the maximum throughput achievable by the protocol (within 0.360177 packet per slot) in infinite population model. In particular we analytically and quantitatively derive the marginal output stream that the system sustains on the channel.
