Abstract : The constraint satisfaction problem - denoted by CSP - consists in proving the emptiness of a domain defined by a set of constraints or the existence of a solution. Numerous applications arise in the computer science field (artificial intelligence, vectorization, verification of programs,...). In the case of the study of dependence computing in automatic parallelization, classical methods in literature may break down for some instances of CSP, even with small sizes. By constrast the new method - denoted by FAS3T (Fast Algorithm for the Small Size constraints Satisfaction problem Type) - we propose allows an efficient solution of the CSP concrete instances generated by the VATIL vectorizer. Comparative computational results are reported.
