Towards document engineering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1990
This article compares methods and techniques used in software engineering with the ones used for handling electronic documents. It shows the common features in both domains, but also the differences and it proposes an approach which extends the field of document manipulation to document engineering. It shows also in what respect document engineering is different from software engineering. Therefore specific techniques must be developped for building integrated environments for document engineering.
Autre [cs.OH]
RR-1244.pdf (917.52 Ko) Télécharger le fichier
inria-00075314 , version 1 (24-05-2006)
  • HAL Id : inria-00075314 , version 1
Vincent Quint, Marc Nanard, Jacques André. Towards document engineering. [Research Report] RR-1244, INRIA. 1990. ⟨inria-00075314⟩
89 Consultations
53 Téléchargements
