Order notions and atomic multicast in distributed systems : a short survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1990
Michel Raynal
  • Fonction : Auteur
  • PersonId : 830511
Understanding distributed systems requires a fine understanding of order relations on the events their executions produce. The first part presents two mechanisms that capture two kinds of relevant orders (Lamport's clocks and Fidge-Matter's clocks). The second part shows how this kind of mechanisms can be used to implement different multicasts in distributed system. This report is essentially a short survey.
Autre [cs.OH]
RR-1197.pdf (897.84 Ko) Télécharger le fichier
inria-00075361 , version 1 (24-05-2006)
  • HAL Id : inria-00075361 , version 1
Michel Raynal. Order notions and atomic multicast in distributed systems : a short survey. [Research Report] RR-1197, INRIA. 1990. ⟨inria-00075361⟩
96 Consultations
106 Téléchargements
