Multiscale system theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1990
In many applications, it is of interest to analyze and recognize phenomena occuring at different scales. The recently introduced wavelet transforms provide a time-and-scale decomposition of signals that offers the possibility of such an analysis. Until recently, however, there has been no corresponding statistical framework to support the development of optimal, multiscale statistical signal processing algorithms. A recent work of some of the present authors and co-authors proposed such a framework via models of "stochastic fractals" on the dyadic tree. In this paper we investigate some of the fundamental issues that are relevant to system theories on the dyadic tree, both for systems and signals.
Autre [cs.OH]
RR-1194.pdf (1.17 Mo) Télécharger le fichier
inria-00075364 , version 1 (24-05-2006)
  • HAL Id : inria-00075364 , version 1
Albert Benveniste, Ramine Nikoukhah, Alan S. Willsky. Multiscale system theory. [Research Report] RR-1194, INRIA. 1990. ⟨inria-00075364⟩
129 Consultations
145 Téléchargements
