About lacunarity, some links between fractal and integral geometry, and an application to texture segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1990
In this work, we apply two techniques for segmentation of different states of one texture (e.g. deformations of an homogeneous texture) : - fractal geometry, that deals with the analysis of complex irregular shapes which cannot well be described by the classical Euclidean geometry - integral geometry, that treats sets globally and allows to introduce robust measures. We focus on the study of two parameters, lacunarity and Favard length, and proove a theoretical link between them. As an application, we are able to achieve automatic classification of lung diseases on the basis on SPECT images.
Autre [cs.OH]
RR-1188.pdf (891.77 Ko) Télécharger le fichier
inria-00075371 , version 1 (24-05-2006)
  • HAL Id : inria-00075371 , version 1
Jacques Lévy Véhel. About lacunarity, some links between fractal and integral geometry, and an application to texture segmentation. [Research Report] RR-1188, INRIA. 1990. ⟨inria-00075371⟩
59 Consultations
114 Téléchargements
