HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Domain decomposition methods for large linearly elliptic three dimensional problems
Abstract : The idea of solving large problems using domain decomposition techniques appears particularly attractive on present day large scale parallel computers. But the performance of such techniques used on a parallel computer depends on both the numerical efficiency of the proposed algorithm and the efficiency of its parallel implementation. The approach proposed herein splits the computational domain in unstructured subdomains of arbitrary shape, and solves for unknowns on the interface using the associated trace operator (the Steklov Poincare operator on the continuous level or the Schur complement matrix after a finite element discretization) and a preconditioned conjugate gradient method. This algorithm involves the solution of Dirichlet and of Neumann problems, defined on each subdomain and which can be solved in parallel. This method has been implemented on a CRAY 2 computer using multitasking and on an INTEL hypercube. It was tested on a large scale, industrial, ill-conditioned, three dimensional linear elasticity problem, which gives a fair indication of its performance in a real life environment. In such situations, the proposed method appears operational and competitive on both machines : compared to standard techniques, it yields faster results with far less memory requirements.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00075376
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 6:05:35 PM
Last modification on : Friday, February 4, 2022 - 3:16:21 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 10:48:55 PM
Identifiers
  • HAL Id : inria-00075376, version 1
Collections
Citation
Patrick Le Tallec, Yann-Hervé de Roeck, Marina Vidrascu. Domain decomposition methods for large linearly elliptic three dimensional problems. [Research Report] RR-1182, INRIA. 1990. ⟨inria-00075376⟩
Share
Metrics
Record views
167
Files downloads
115
