Abstract : Considering the TVD methods as accuracy-adaption methods, we propose a strategy for deciding mesh refinements for TVD-approximated compressible flows. Both mesh enrichment and deformation are applied to typical test cases involving shocks boundary layers : a flow past a flat plate and flows around an airfoil.
https://hal.inria.fr/inria-00075383 Contributor : Rapport de Recherche InriaConnect in order to contact the contributor Submitted on : Wednesday, May 24, 2006 - 6:06:34 PM Last modification on : Friday, February 4, 2022 - 3:11:40 AM Long-term archiving on: : Tuesday, April 12, 2011 - 6:46:15 PM
Bernadette Palmerio, Loula Fezoui, Christian Olivier, Alain Dervieux. On TVD criteria for mesh adaption for Euler and Navier-Stokes calculations. [Research Report] RR-1175, INRIA. 1990. ⟨inria-00075383⟩
