Dissipative properties of Runge-Kutta schemes with upwind spatial approximation for the Euler equations
Abstract : We present in this paper how to construct a 4-stage Runge-Kutta method when the spatial approximation is a Muscl-type upwind scheme for the solution of the two-dimensional Euler equations. A theorical study is first conducted in the one-dimensional linear case, and then extended to the two-dimensional case where the equations are solved by multigrid techniques over unstructured finite element meshes. A few numerical experiments are presented, demonstrating the validity of the theoretical results.
Type de document :
Rapport
[Research Report] RR-1173, INRIA. 1990
Liste complète des métadonnées
https://hal.inria.fr/inria-00075385
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 18:06:49
Dernière modification le : samedi 27 janvier 2018 - 01:31:01
Document(s) archivé(s) le : mardi 12 avril 2011 - 22:52:39
Fichiers
  • HAL Id : inria-00075385, version 1
Collections
Citation
Marie-Helene Lallemand. Dissipative properties of Runge-Kutta schemes with upwind spatial approximation for the Euler equations. [Research Report] RR-1173, INRIA. 1990. 〈inria-00075385〉
Métriques
Consultations de la notice
338
Téléchargements de fichiers
98
