The periodic Boltzmann semiconductor equation - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1990
Roland Glowinski
  • Function : Author
Patrick Le Tallec
Jean-François Palmier
  • Function : Author
This paper is concerned with the numerical solution of the Boltzmann semiconductor equation. Our main objective is the development of a fast deterministic solution procedure for the numerical computation of the steady state solutions. The discretization strategy is based on an upwind finite difference approximation of the gradient terms and on a deterministic conservative calculation of the integral operators. The resulting algebraic system is then solved by a least squares methodology which reduces the system to a quadratic minimization problem to be solved by a standard conjugate gradient algorithm.
RR-1169.pdf (1.26 Mo) Télécharger le fichier
Dates and versions
inria-00075389 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00075389 , version 1
Cite
Jean-François Bourgat, Roland Glowinski, Patrick Le Tallec, Jean-François Palmier. The periodic Boltzmann semiconductor equation. [Research Report] RR-1169, INRIA. 1990. ⟨inria-00075389⟩
104 View
31 Download
Share
