HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
On the representation of memory references generated by a program with application to the analysis of cache memories
Abstract : In this paper we propose a stochastic model of the sequence of memory references generated by a program. We derive explicit expressions of the main characteristics related to such sequences : working set behavior, miss rates in the case of an architecture with a cache. The problem of (spatial/temporal) locality is addressed and the stochastic models proposed in the literature (the IRM model mainly) are discussed from this point of view. Examples with real traces generated by benchmarks of fortran programs are presented.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00075400
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 6:08:50 PM
Last modification on : Thursday, February 3, 2022 - 11:14:35 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 10:57:22 PM
Identifiers
  • HAL Id : inria-00075400, version 1
Collections
Citation
Christine Fricker, Philippe Robert. On the representation of memory references generated by a program with application to the analysis of cache memories. [Research Report] RR-1158, INRIA. 1990. ⟨inria-00075400⟩
Share
Metrics
Record views
74
Files downloads
23
