Distributed primality proving and the primality of (2 +1)/3 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1989
F. Morain
  • Fonction : Auteur
The aim of this report is to explain the implementation of the elliptic curve primality proving algorithm of Atkin in a distributed way. We describe the use of a Le_Lisp program managed by a bunch of script-shells that run processes on different workstations communicating via the distributed file system NFS. As a result, the primality of 700-digit numbers can be done routinely in about a week of CPU on 10 SUN's. Using twelve SUN's and one month and half CPU, the author was able to prove the primality of a very large number (1065 digits) . This is (up to now) the record for the largest number ever tested for primality by a general purpose algorithm.
Autre [cs.OH]
RR-1152.pdf (635.27 Ko) Télécharger le fichier
inria-00075407 , version 1 (24-05-2006)
  • HAL Id : inria-00075407 , version 1
F. Morain. Distributed primality proving and the primality of (2 +1)/3. RR-1152, INRIA. 1989. ⟨inria-00075407⟩
49 Consultations
66 Téléchargements
