Abstract : Wegive an analytical evaluation of the high speed protocol, QPSX, under a simple model. We suppose that the number of connected nodes is (virtually) infinite, providing a global load l < 1 ; the distances between the nodes are large and randomly distributed. An analogy is developed with queueing systems with two files in tandem, which lead to analytical evaluation via closed formulas.
