HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
A finite element method to solve the compressible Navier-Stokes equations in 3D with mesh enrichment procedure
Abstract : A new computer code solving the compressible Navier-Stokes equations is described. The code solve the three-dimensional (3D), time-independant equations using the finite element method based on the P1-P1isoP2 element. Actually the numerical stability is ensured by a simple artificial viscosity method which will be improved in a future version. The results of numerical experiments for the flow around an ellipsoid will be presented in order to show the possibilities of the methods used. Finally, we discuss an efficient mesh enrichment procedure which can be used in 2 or 3 dimension.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00075443
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 6:13:35 PM
Last modification on : Friday, February 4, 2022 - 3:15:25 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 7:00:33 PM
Identifiers
  • HAL Id : inria-00075443, version 1
Collections
Citation
Samuel Boivin. A finite element method to solve the compressible Navier-Stokes equations in 3D with mesh enrichment procedure. [Research Report] RR-1116, INRIA. 1989. ⟨inria-00075443⟩
Share
Metrics
Record views
87
Files downloads
59
