Evaluation of job-shops with random manufacturing times : a Petri net approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1989
In this paper, we use event graphs, a paricular type of Petri nets, to evaluate job-shops when manufacturing times are random variables and the control is defined as the sequence of product types at the entrance of each machine. Under very general assumptions, we prove that the cycle time of the system converges in probability to a constant and asymptotically tends in distribution to a normal distribution whose standard deviation tends to zero. We also provide a lower bound of the main cycle time. We finally derive from the previous results a heuristic algorithm which leads to a near optimal solution of the problem (an optimal solution being the minimal work-in-process which allows the maximal productivity, i.e. the minimal cycle time, knowing the control).
RR-1112.pdf (860.87 Ko) Télécharger le fichier
inria-00075447 , version 1 (24-05-2006)
  • HAL Id : inria-00075447 , version 1
Saïd Laftit, Jean-Marie Proth. Evaluation of job-shops with random manufacturing times : a Petri net approach. [Research Report] RR-1112, INRIA. 1989, pp.15. ⟨inria-00075447⟩
51 Consultations
97 Téléchargements
