A unified physical presentation of mixed, mixed-hybrid finite elements and usual finite differences for the determination of velocities in waterflow problems
Abstract : The objective of this paper is to give a non-mathematical presentation of mixed finite elements, following as much as possible physical intuition and natural good sense. Mixed and mixed hybrid finite elements are clearly presented as two formulations of the same approximation and the use of a quadrature rule is shown to reduce both formulations to the usual finite difference scheme. Application to the resolution of stationary (elliptic) and time dependent (parabolic) water flow problems is discussed in detail for the case of a uniform rectangular grid, and the enhancement in the approximation of velocities is emphasized. Generalizations and order of convergence are discussed.
Type de document :
Rapport
[Research Report] RR-1107, INRIA. 1989
Liste complète des métadonnées
https://hal.inria.fr/inria-00075452
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 18:15:09
Dernière modification le : vendredi 16 septembre 2016 - 15:11:39
Document(s) archivé(s) le : mardi 12 avril 2011 - 23:09:39
Fichiers
  • HAL Id : inria-00075452, version 1
Collections
Citation
Guy Chavent, Jean Roberts. A unified physical presentation of mixed, mixed-hybrid finite elements and usual finite differences for the determination of velocities in waterflow problems. [Research Report] RR-1107, INRIA. 1989. 〈inria-00075452〉
Métriques
Consultations de la notice
199
Téléchargements de fichiers
138
