HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Recursive filtering and edge closing : two primary tools for 3d edge detection
Abstract : This paper deals with edge detection in 3d images such as scanner, magnetic resonance (NMR), or spatio-temporal data. We propose an unified formalism form 3d edge detection using optimal, recursive and separable filters recently introduced for 2d edge detection. Then we obtain some efficient 3d edge detection algorithms having a low comptutational cost. We also show that 3d edge closing enable to extract many edges not provided by the filtering stage without introducing noisy edges. Experimental results obtained on NMR images are shown.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00075456
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 6:15:41 PM
Last modification on : Friday, February 4, 2022 - 3:16:53 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 11:10:34 PM
Identifiers
  • HAL Id : inria-00075456, version 1
Collections
Citation
Olivier Monga, Rachid Deriche, Grégoire Malandain, J.P. Cocquerez. Recursive filtering and edge closing : two primary tools for 3d edge detection. RR-1103, INRIA. 1989. ⟨inria-00075456⟩
Share
Metrics
Record views
128
Files downloads
295
